Inspire view service not working when testing capabilities
652
12-19-2011 04:27 AM
FIRLEJSamuel
I'm actually trying the Arcgis for Inspire extension, and Geoportal.
I installed Inspire extension on my ArcGis 10 SP3, and create a new Inspire View Service with WMS capabilities. This service seams OK in Arccatalog, but when I test its capabilities as described in the documentation using this URL:
http://tsig:8399/arcgis/services/inspire/MapServer/InspireViewService?request=GetCapabilities&servic...
I get the following java/Tomcat error:
Etat HTTP 500 - Error during processing: com.esri.a4i.ifc.soe.api.SOEException: error during processing ags task at server <localhost>. Msg: java.lang.ClassCastException: A COM object reference via iid 9f9650f1-5f49-4041-ba0f-d10baff1d7bc does not support COM interface b139fddb-1e44-386d-b5c2-8cf065f992c7
type Rapport d'�tat
message Error during processing: com.esri.a4i.ifc.soe.api.SOEException: error during processing ags task at server <localhost>. Msg: java.lang.ClassCastException: A COM object reference via iid 9f9650f1-5f49-4041-ba0f-d10baff1d7bc does not support COM interface b139fddb-1e44-386d-b5c2-8cf065f992c7
description Le serveur a rencontr� une erreur interne (Error during processing: com.esri.a4i.ifc.soe.api.SOEException: error during processing ags task at server <localhost>. Msg: java.lang.ClassCastException: A COM object reference via iid 9f9650f1-5f49-4041-ba0f-d10baff1d7bc does not support COM interface b139fddb-1e44-386d-b5c2-8cf065f992c7) qui l'a emp�ch� de satisfaire la requ�te.
Apache Tomcat/6.0.18
Has anyone any idea about the possible origin of this problem?
Thank's
Sam
PhilipThompson
Hi Sam,
Did you ever get to the bottom of this? I am suddenly seeing my log files fill up with these error messages where previously there were none. I'm not aware of any system changes.
Phil.
