Is US Dual Ranges broken in 10.0 sp4 if you map ZIP? very slow w/o?
417
04-19-2012 07:30 AM
HarryBowman
New Contributor III
Case 1:
Streets are in file geodatabase and mapped addresses, type, street name, etc.
Mapped L/R city
Mapped L/R State
Did not map L/R Zip
Results: very slow
Case  2:
Mapped L/R city
Mapped L/R State
Mappe L/R Zip 'CORRECTION: DID MAP L/R Zip Initial post had this incorrect'
Results: 0 candidates
Am I missing something? The L/R Zip is Canadian FSA, example: H3X
JoeBorgione
Case 1:
Mapped L/R city
Mapped L/R State
Did not map L/R Zip
Results: very slow
Case  2:
Mapped L/R city
Mapped L/R State
Did not map L/R Zip
This might be a similar situation to a problem I was having a few weeks ago.
It seems that the 10.x locators are a little more particular than we've seen in the past; you may need to map your zip codes.
HarryBowman
New Contributor III
Correction to initial post: In the second, zero candidate case, I did map the zips. They were Canadian FSAs, like H3X.
HarryBowman
New Contributor III
Did an experiment. Instead of the real FSAs as Postal Code (ex: h3x) used a fake: 12345. Worked. OK....why?
JoeBorgione
Ohhhh.... Canandian data.... All bets are off!  No; just kidding...  Thats a really good question!
