LOAD OBJECTS CAUSE CRASH
1026
13
11-29-2010 05:54 AM
BernardSennstrom
Since installing the SP1 for ArcGIS 10 I can no longer load objects. As soon as I pick the Load Objects button the software crashes. Has anybody else had this happen? Is there a fix coming from ESRI other than using a work around like the Append Tool?
IainGover
I have the problem as well but have found that the load data function in arcCatalog still works well and is a good interim solution
ChrisFox3
The ArcGIS 10.0 SP1 (Desktop) Load Objects Command Patch has now been released and will resolve the issue described in this forum thread.
JoelSabin
I had that patch installed this morning, but the tool still causes a crash when I try to use it.
My computer: Dell Optiplex 745, Pentium D, XP 2002 SP3
ChrisFox3
Hi Joel,
I would encourage you to contact Technical Support for this issue. They will have the resources and knowledge to appropriately assist you in this matter.
