Hi all:
I have a dataset that contains multiple facilities, misc data, and their x,y coordinates in UTM. I have added new records and modified some existing records in the shapefile's attribute table. However, these new/modified records do not display once I stop and save the edit session.
Also, I have a subset of the dataset described above, created via selection by attribute and exported into a new shapefile that does not update either when I recreate the new shapefile after modifying the attribute table.
Any idea what I'm doing wrong here?
