not able to save georeferenced file
3791
6
04-14-2015 08:49 AM
ritisharma
Hi
I am not able to save georeferenced file. When I georeferenced the tiff file and rectify and try to save, it just takes forever and still would not save and I have to close arcmap. Any help is appricated.
JakeSkinner
Esri Esteemed Contributor
Hi Riti,
What is the uncompressed size of your TIFF file?  You can check by right-clicking on the TIFF > Properties > Uncompressed Size.
ritisharma
749 kb
JakeSkinner
What format are you trying to save the new rectified image to?  i.e. TIFF, BMP, File Geodatabase?  Does the same problem exist when saving to different formats?
ritisharma
I am working on tiff. I haven't tried on other formats but it was working on other tiff file until yesterday
RakeshSinha
Hi Riti,
I would try Jake’s suggestion of trying a different output format to see if the result differs. However, just out of curiosity I would also try recalculating the statistics of the TIFF in question and re-building the pyramid layer before Georeferencing.
KishorGhatage
For a test just have a backup of your image and use 'Update Georeferencing' and observe the behavior.
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
