Hello,
Can anyone possibly suggest the best method for loading data into a versioned feature class that is part of a geometric network? I have a versioned feature class of streetlights in a geodatabase that is part of a geometric network. I also have another non-versioned feature class of additional streetlights I want to add to the versioned data. The schemas in both do match.
There are many streetlights 15,000+ in the non-versioned data.. I have begun using copy & paste in an edit session with the versioned data as the target layer. This approach does work if I copy small numbers of rows each time (say 50-100).. however it is very time consuming.
I have tried object loader, but it fails each time.. I often run out of memory..
Any ideas?
JS
Hello,
Any ideas?
JS
Hello,
Any ideas?
JS
