Hello,
I have a point feature class that was created by geocoding a bunch of addresses out of an excel table. When these points are added to my map, it appears that only a small portion of them are displaying. I cannot determine why this is happening.
The point feature class contains 30,539 points. I have selected a subset of around 25,152 of those 30k points. Yet on my map it is only showing around 20 point as being part of that selection. For some reason ArcMap is not displaying all of the points.
I am wondering if there is some sort of setting turned on that is filtering out the display of all points in order to optimize display rendering or something along these lines? I have attempted to export this FC as a new FC and get the same result.
Attached is a screenshot. Notice at the bottom where it says 25152 out of 30539 selected, yet in the map view I am only seeing about 15-20 points...(I had to hide some fields in my attribute table)
Your contributions are greatly appreciated. Hopefully this is an easy one to solve for you experts out there.
