FAQ: What PostgreSQL Database Versions Are Supported by ArcGIS Enterprise and ArcGIS Pro? (esri.com)
ArcGIS 10.9.1 and ArcGIS Pro 2.9 requirements for PostgreSQL—ArcGIS Enterprise | Documentation for A...
PostgreSQL 13.3 is the minimum certified and supported version and customers can update the PostgreSQL 13 to the latest version to get the latest security updates and bug fixes.
See my community.esri.com blog about upgrading PostgreSQL and PostGIS for Enterprise Geodatabases.
How to Upgrade the PostgreSQL and PostGIS version for the Enterprise Geodatabase on Windows
How to Upgrade the PostgreSQL and PostGIS version for the Enterprise Geodatabase on Linux
Can we thus safely assume pg13.13 is compatible with ArcGIS Server 10.9.1? And with ArcPro 3.1/3.2?
Yes, PostgreSQL 13.13 is compatible and supported with ArcGIS Server 10.9.1.
If using ArcGIS Pro 3.1 / 3.2 then you shall upgrade the ArcSDE Geodatabase Repository.
If you use ArcGIS Pro 3.2 to upgrade the Geodatabase Repository then this will bring the Geodatabase Repository to version 11.2.0.3.2.
It is a best practice to keep all ArcGIS software components at the same release, therefore you need to upgrade to ArcGIS Server 11.2.0.
You could go to PostgreSQL 15 + ArcGIS Pro 3.2 + Geodatabase 11.2.0.3.2 + ArcGIS Server 11.2.0.
ArcGIS 11.2 and ArcGIS Pro 3.2 requirements for PostgreSQL—ArcGIS Enterprise | Documentation for Arc...
Client and geodatabase compatibility—ArcGIS Pro | Documentation open the link to read the full document.
You do not have to keep your geodatabase and ArcGIS clients at the same release, but it is recommended that you do so. Geodatabases and client software are designed to work together, and if you let one get too many releases away from the other, you risk encountering problems or unexpected behavior.
Does ESRI recommend acquiring supported postgres installation (for windows) for download from My Esri, instead of postgresql.org ? Is there any potential issue if the installation is acquired from postgresql.org especially when the version needed is not yet available from My Esri for example?
This is a customer choice, but yes you can download PostgreSQL from postgresql.org.
How to Move the PostgreSQL Enterprise Geodatabase with pg_dump and pg_restore
For more best practices go to my community.esri.com blog below.
Mapping and Charting Solutions (MCS) Enterprise Da... - Esri Community
Read the production mapping database guide books for PostgreSQL, the best practices can be applied to any industry, you can also find there my database template scripts for PostgreSQL and the database connection best practices.
| Marcelo Marques | Principal Product Engineer | Esri |
| Cloud & Database Administrator | OCP - Oracle Certified Professional |
I work with Enterprise Geodatabases since 1997.
“ I do not fear computers. I fear the lack of them." Isaac Isimov
