Problems to install INSPIRE 10.2.1
847
02-18-2014 10:05 PM
UldisGitendorfs
Hi.
Here is the problem. I have a virtual machine with Win server 2008R2. I have installed ArcGIS server 10.2.1 on it. But I'm not able to install INSPIRE extension. In the window where to write in arcgis url , username and password none of machinename:6080 or localhost:6080 nor with IP works. All I got is
"An error has occured locating Arcgis server
Please re-enter ArcGIS server Instance url"
When trying those links in Web browser, only localhost:6080 works.
Machine is not in domain, just in WORGROUP.
Should there be any special network configurations or what?
In test case I tried all that installation on a real PC win7, connectet to domain, and all installations worked fine.
Maybe there should be some special server components enabled?
Please help!
UldisGitendorfs
SOLVED
It was just a proxy server specific error.
Just had to make a check in IE/Tools/Connections/LAN settings "Bypass proxy server for local addresses"
