I want to change programmatically change the target layer and the snapEnvironment(vertex, edge, end) of a layer(s) I knew how to do it in arcMap 9.3 using IEditor, ISnapEnvironment and IEditLayers but since EditorToolbar has changed it seems that that code doesn't work in arcMap 10 could you please tell me how to do it???
Your code should work, but you will need to revert back to the classic snapping environment via IEditProperties4.ClassicSnapping or assume this is done on the editor options UI.
this method is used to set targetLayer in editor(target layer comboBox in arcMap9.3) and set the snap environment, this code doesn't throw any exception but it doesn't work, could you tell me please what things I should change to get this working in arcMap 10??
also could you tell me how to programmatically start a EditTask.?
