Did you set a transformation (datum shift) under the cords tab in the data frame properties page?
You have a single geocentric transform available (ArcGIS v10.2) for WGS84 to/from Kandawala, dx, dy, dz parameters -97.0, 787.0, 86.0.
That will be the likely cause of your 200m shift.
Neil
