When exporting or importing from SDE to a PGDB the record counts are different. The SDE data we are doing this with is a spatial view and exporting or importing to a shapefile in a PGDB. I am not sure why or how I would explain this difference to someone and would like to know if there is a common reason for this to occur. In this once case our data exported from sde has 67 more records in the data than the record count in SDE. And we are comparing the record counts using catalogue, ArcMAp, Access and SQL. The Arc products are seeing the difference BUT Access sees the same counts. I am guessing it may have to do with delta tables?? Not sure. Any input would be helpful! Thanks in advance!
