We use a custom projection for our geodatabase and it has always been named "NAD_1983_Transverse_Mercator". I would like to change the name of the projection to something less generic that captures the name of our company in the title, for example "Idaho_Power_Transverse_Mercator". The projection parameters remain the same, just the title would change. I've tried using the Define Projection tool but it fails to write over any existing projection parameters. Can I remove a projection definition in a geodatabase and then run the Define Projection tool to reassign the parameters? Any other suggestions?
Mike
