If you require TIFFs, I would recommend running the Project Raster tool. In order to get rid of the blank edges, you can set the NoData value within the Environments. I'm assuming the values 0,0,0 are being converted to the black edges. If this is the case, you can set the NoData value to 'MINIMUM'. This will convert the 0,0,0 values to NoData. Ex:
