Shapefile vs. Arcmap (.mxd)
2600
03-06-2012 11:25 AM
DawnNelson
My working knowledge of ArcMap is quite limited, and my task is to merge multiple county maps (.mxd) into one state level shapefile. however, i have multiple .mxd files with geocoded information and am not sure how to proceed to get the desired outcome (one shapefile). Please advise! Thanks!
Tags (3)
KatharinaDubach
Occasional Contributor III
You will need to merge your shapefiles and then build a new map from that.
For starters, you can move the data between different mxd's using drag-and-drop or by right-clicking>copy, then "Paste Layers".
Now, using ArcToolbox, search for a tool called "Merge" (I think it's in Data Management, but I'm not sure any more) and use this to merge the county-Shapes into a new State-shape.
Important: If the attribute tables of the county-shapse have identical field names, this will work well. If the field names don't match, you'll end up with empty fields and missing information, so you might want to check that first.
