Spatial Adjustment doesn't adjust Point-Features
781
09-26-2012 06:55 AM
MatthiasKampf
Hi Community!
I'm trying to move an old map with an unknown reference system to its UTM coordinates using the Spatial Adjustment toolbar.
It works fine for Polygon-Features, but the Point-Features won't move at all.
RMS-Error is between 3 and 5 depending on the transformation method.
I tried to select them seperately, all together, by type, switched the editing mode, switched the adjustment method, etc. but nothing works.
Can anybody help me, please?
Greetings, Matt
JuanLuera
Occasional Contributor III
Hola Matthias,
This looks like an issue to have an incident opened with us within Support Services to provide assistance with this issue. If you are current with your maintenance, please submit a webform and we will be happy to assist. We can then open an incident and you can provide us with the data to work with you through this issue being seen. Gracias, Matthias!
Support Service
1-888-377-4575
http://support.esri.com/en/webform/s...275/chat/false
HardolphWasteneys
Matt,
did you use the "Set Adjust Data" parameters to select the point layer file as well as the polygon layer?   By default selected features would be adjusted, but you might have better luck with the "All features in these layers" parameter and select the files specifically.
Hardolph
