Stata to Geodatabase Conversion (400-500 fields in .dta file)
1473
07-26-2011 08:25 AM
DanielSheehan
What is the best way to convert a Stata file into a geodatabase? I have many fields, 400-500, the Stata file. I have Stat Transfer and I usually transfer from Stata to .dbf but when there's this many fields it will not work.
VinceAngelo
Esri Esteemed Contributor
Are you looking to transfer to a file geodatabase or an ArcSDE database?
Which version of ArcGIS?  If ArcSDE, which database?
- V
DanielSheehan
ArcGIS 10, File Geodatabase
In addition if some of the Stata fields begin with underscores, at what point and in what software can I change these? I'm assuming FGDB does not like field names that start with underscores.
VinceAngelo
Most pre-10 ArcSDE database limit the column count to 256, but at 10.0 the ArcSDE limit was
increased to 500 (SE_MAX_COLUMNS).  The FGDB limit is 64K fields, but I believe they must
start with a character ([A-Z](A-Z0-9_)* - SQL requirement).
You're probably going to have to code this from scratch, so it doesn't really matter where you
make the change.  The fastest approach would use C++ (either ArcObjects or FileGDB API),
but if you don't have a lot of rows, C# or Python won't slow you down too much.
What interface do you have at the Stata end for accessing raw data?  Or would you plan to use
ASCII for interchange?
- V
