The system cannot find the path specified
4030
09-20-2010 12:31 PM
RickObsitnik
Hey All
I'm receiving the following error when trying to start a newly created sde service:L
[INDENT]The ArcSde Service(<service name>) service failed to start due to the following error:
The system cannot find the path specified.[/INDENT]
Here's the command used to create the service:
[INDENT]sdeservice -o create -p <box admin password> -H "c:\program files (x86)\arcgis\arcsde" -i <service name> -d SQLSERVER,<SQL Server hostname\instance> -u <domain acct to run service>  -P <domain acct password> -s <DB name>
[/INDENT]
I'm assuming the path specified is the SDEHOME.  Sound right?  If so, it's correct.
VinceAngelo
Esri Esteemed Contributor
If you check your service properties, you might find that the "path to executable" is invalid.
I almost never use the -H option, because I always explicitly set SDEHOME and PATH
before invoking 'sdeservice':
set SDEHOME=D:\ESRI\arc100sql32-sp0\ArcSDE\sqlexe
set PATH=%SDEHOME%\bin;%PATH%
sdeservice -o create ...
I also avoid spaces and special characters in my SDEHOME directories, even though it
shouldn't make a difference (old habits...)
- V
RobertRenner
Somewhat related to this thread I'm trying to set my SDEHOME variable but unfortunatley SDEHOME is in Program Files directory and it looks like the space is causing the trouble.
E:\Program Files\ArcGIS\ArcSDE\ora11gexe
What are my options here?
VinceAngelo
1) Uninstall, then reinstall without spaces
2) Use the 8.3 name for Program Files (if available)
3) Use double-quotes around the string
- V
