Translation to SDE error
1203
02-11-2011 10:40 AM
ShilpaBhadsavle
Hi!
I have tried to alter various connection parameters at destination, but none works and I get a following error:
" Installed ArcGIS version is '10.0.2414'
An ArcGIS license is already checked out. The product checked out is 'ArcInfo'
Could not open the Enterprise Geodatabase. Please check that the connection parameters specified are correct. The error number from ArcObjects is: '-2147216021'. The error message from ArcObjects is: {Entry for SDE instance not found in services file}
Closing the Geodatabase writer
A fatal error has occurred. Check the logfile above for details"
Any suggestions?
Shilpa
SeanGrant
I usually see that error when it can't find the server I specify.Have you tried entering in the IP address of the server rather than the name? Without looking at the connection properties you have tried it is hard to see what is wrong.
-Sean
