Xander and Joe are on the right track...
Examine the address from the perspective of non-standard lengths brought about the uncertain number of spaces separating elements in the address.
>>> # parsing non-standard address...problem examination
>>> address = "123 Northwest Johnson St Cleveland Ohio 12345"
>>> bits = address.split(" ") # split it into its components
>>> bits
['123', 'Northwest', 'Johnson', 'St', 'Cleveland', 'Ohio', '12345']
>>> for fiddly in range(len(bits)): # now lets examine the fiddly bits
... print bits[:-fiddly], "step", fiddly
[] step 0
['123', 'Northwest', 'Johnson', 'St', 'Cleveland', 'Ohio'] step 1
['123', 'Northwest', 'Johnson', 'St', 'Cleveland'] step 2
['123', 'Northwest', 'Johnson', 'St'] step 3
['123', 'Northwest', 'Johnson'] step 4
['123', 'Northwest'] step 5
['123'] step 6
>>> # Now for problem address 2
>>> address = "PO Box 3 Pine Springs Ohio 12345"
>>> bits
['PO', 'Box', '3', 'Pine', 'Springs', 'Ohio', '12345']
[] step 0
['PO', 'Box', '3', 'Pine', 'Springs', 'Ohio'] step 1
['PO', 'Box', '3', 'Pine', 'Springs'] step 2
['PO', 'Box', '3', 'Pine'] step 3
['PO', 'Box', '3'] step 4
['PO', 'Box'] step 5
['PO'] step 6
>>> # In address 1 it took until step 3 to get rid of everything
>>> # up to the city level. in address 2 this was completed by step 2...
>>> # Conclusion? Unless the address contain the same number of elements
>>> # it is not possible to parse data in one pass
A good reason to parse during data collection and entry.
Do note... that a screw will be thrown into the works when you start mixing state names which are multipart as well...consider
address = "123 Northwest Johnson St South New York New York 12345" # Now What!!!
