I have run into a wall and am in need of some direction. I recently tried to create a new feature class using ST_GEOMETRY and I cannot get the feature class to draw in ArcMap. I have the same issue when trying to preview the feature class in ArcCatalog.
The selected object failed to draw: ST_GEOM_TEST: Underlying DBMS error [ORA-00942: table or view does not exist][APPDEV1.ST_GEOM_TEST]
So, I have an Oracle 11g database with SDE 10.0 installed. Full disclosure on the upgrade to 10.0 from 9.3.1 is that we did not have the proper set up for ST_GEOMETRY on our database server box. We do not use SDE service anymore and were not planning to use ST_GEOMETRY. I have since updated the SDE libraries to know where to find the ST_GEOMETRY and RASTER .so binaries. We are running IBM AIX 6.1. There were some invalid objects that recompiled to valid after I fixed the SDE libraries. I also re-configured the listener per the instructions and all of that seems to be working properly.
I can use sde -o describe and describe_long on the table. The long description is below (fields between OBJECTID and SHAPE omitted for space preservation).
ArcSDE 10.0 for Oracle11g Build 2063 Tue May 22 14:45:23 2012 Attribute Administration Utility ----------------------------------------------------- ---------------------------------------------------------------- Column Owner : APPDEV1 Column Table : ST_GEOM_TEST Column Name : OBJECTID Row ID Column Type : SDE Maintained SDE Column Type : SE_INT32 Column Size : 10 Decimal Digits : 0 Null Allowed? : False
I had a client site where a script was run to "secure" the database, and it wound up removing all sorts of necessary permissions from the ST_GEOMETRY packages, which generated spurious "does not exist" errors ("SDE.function" was interpreted as "SDE.table", so the error wasn't about the package). I had to exercise all the ST_* methods to demonstrate the issue, then used an operational instance to determine which EXECUTEs had been removed from PUBLIC. Tech Support could help you do the same.
Okay, I am back in ST_GEOMETRY business. The problem had a few causes.
The database and database server were not properly set up to use ST_GEOMETRY (see help)
Privileges were not granted to PUBLIC on all of the ST_% objects - EXECUTE and some SELECT, UPDATE, INSERT, DELETE
PUBLIC Synonyms were not created on all the necessary ST_% objects
To get up and running again:
Configured the database and database server correctly (see help)
[INDENT]
Created the proper libraries pointing to the ST_GEOMETRY binaries
Added entries in the database server tnsnames.ora and listener.ora
Recompiled the invalid ST objects in the SDE schema
[/INDENT]
Applied the proper privileges to the ST_GEOMETRY objects
[INDENT]
I was fortunate enough to get my hands on the grants of a fresh proper 10.0 database - thanks Jake
Using that I compared the grants to what my DB had
Here's the select statement to get the grants:
[INDENT]
select grantee, owner, grantor, privilege, table_name from dba_tab_privs where owner='SDE' and table_name LIKE 'ST_%' order by table_name;
[/INDENT]
The grants that I was missing were added to a SQL script that I ran against the DB
[/INDENT]
Create the PUBLIC synonyms still needed
[INDENT]
Jake hooked me up again with a nice list of the synonyms from a good DB
That was compared to my DB
I created a sql script to create the synonyms
Here are the select statements to retrieve the necessary synonyms
[INDENT]
select synonym_name from all_synonyms where owner = 'PUBLIC' and synonym_name LIKE 'ST_%';
select synonym_name from all_synonyms where owner = 'PUBLIC' and synonym_name LIKE 'USER_ST_GEOM%';
select synonym_name from all_synonyms where owner = 'PUBLIC' and synonym_name LIKE 'ALL_ST_GEOM%';
[/INDENT]
[/INDENT]
So, thank you to Vince for pointing me in the direction of my problem and thank you to Jake for getting me what a correct DB should be. I've attached the output of what the proper DB privileges and synonyms should be.
