I am trying to check out a feature class in a personal geodatabase to arcpad (using arcpad data manager toolbar in ArcMap 10). When I try to check out, I get the following error:
"Validation failed for 95 features in the Gas_Taps feature class. The first reported failure is on feature ID 1: Field Active attribute value Y is not a member of coded value domain Active.
You must correct this before you can check out Gas_Taps."
The field "Active" is a Yes (Y) or No (N) field. What do I need to correct this?
Thanks in advance.
