Hi, I'm back.
So I've successfully clipped the extent of all of my layers by drawing a polygon from the Draw toolbar and then going into the Data Frame Properties of the layer and clipping by that polygon. However, when I go into the data attribute table for any of my point feature classes, they still have the same number of records as they did before the clip.
I need to actually remove all data that is outside of the clipped extent from my tables. Not sure if it would help anyway, but I apparently don't have whatever license is needed for the Erase tool.
Is this doable without it?
Ryan
