ArcGis Pro keeps crashing when I attempt to add erase point to my model
404
04-27-2017 04:46 PM
PejvakZaimaran
New Contributor II
Thanks for the help
DanPatterson_Retired
As indicated in a previous thread, a select by location will use only the selected points in the next step.  There is no reason to remove/hide points that aren't selected.  Your model would then have to clip the original data using the buffer, then remove the original layer... making the model unwieldy and not something really appropriate to modelbuilder, but perhaps python scripting using the mapping module.
Is there a reason that you want the points outside the buffer to 'disappear" other than aesthetics?
