Attribute Assistant toolbar with join fields
2759
02-18-2015 05:39 AM
JoseSanchez
Occasional Contributor III
Good morning everyone,
Does the attribute assistant work with layers that are joined with attributes dynamically in the map. I would like to know if I can add a rule that imports a field from a layer in the map that is a joined field, not a field from the base feature class.
Thanks
AaronLowe
New Contributor III
I tested this out and it appears that it's unable to pull from joined fields.
