Error Installing Experience Builder Dev Edition 1.9
638
11-08-2022 08:02 AM
mpboyle
Occasional Contributor III
I'm trying to install Experience Builder 1.9 and am running into issues when trying to install the client.
Below are the errors being through when running "npm ci" within the client folder.
Python is set as a system environment variable.  However, because I'm using a machine that has Pro installed, when I run python from the cmd, I get a conda warning about the environment not being activated.  I'm not sure if that's the issue or not.
In any case ... any ideas how to get the client installed so I can use the developer edition?
mpboyle
For anyone else who may have a similar issue ...
It was found that using a version of node.js prior to version 18 worked as expected.
Trevor_Hart
You can force the python path by running this command;
npm ci --python="C:\Program Files\ArcGIS\Portal\framework\runtime\python\python.exe"
This gets me past that error
