error using st_point with stored procedure (works in sqldeveloper but not in java)
4291
03-31-2015 05:32 PM
davidzornosa
New Contributor III
A simple procedure:
    create or replace PACKAGE BODY TEST_PACK AS
    procedure test as
    begin
        insert into table_evw(shape) values (sde.ST_GeomFromText('point ('|| -73.16 || ' ' || 6.78  || ')', 4686));
    end test;
    END TEST_PACK;
ran it in sqldeveloper:
    begin
    TEST_PACK.test;
    end;
runs fine, i get a brand new record on 'table_evw'.
But when i invoke it from java
    CallableStatement cs = c.prepareCall("{call test_pack.test}");
    cs.executeQuery();
I get this horrible exception
    ORA-20004: Error generating shape from text: Shape has too many parts (-5).
I've already tried
    alter instance set NLS_NUMERIC_CHARACTERS = ".,";
And it doesnt work
Oracle 11g.
ArcGIS 10.2
Thanks.
Tags (3)
CarlosNantes
New Contributor III
This is still a question in 2021. I had the same issue today when using SDE.ST_POINT(). Turns out that the problem is related to NLS_NUMERIC_CHARACTERS config.
SDE.ST_POINT will throw "Shape has too many parts"  if NLS_NUMERIC_CHARACTERS =",.". This is probably the case for sde.ST_GeomFromText().
To solve the issue, use  dbms_session.set_nls() in the first line of the stored procedure or function as follows:
    procedure test as
    begin
         dbms_session.set_nls('NLS_NUMERIC_CHARACTERS', '".,"');
    end test;
Solution found here: StackOverflow
