I need help getting the following map/code to show up, but have the map gallery as the basemap.
My code
arcgisUtils.createMap("511bd0e84f1441edb7bf55167ecddec2", "map").then(function (response) {
//update the app
dom.byId("title").innerHTML = response.itemInfo.item.title;
dom.byId("subtitle").innerHTML = response.itemInfo.item.snippet;
map = response.map;
//add the scalebar
scalebar = new Scalebar({
map: map,
scalebarUnit: "english"
overviewMapDijit = new OverviewMap({
map: map,
visible: true
overviewMapDijit.startup();
//add the legend. Note that we use the utility method getLegendLayers to get
//the layers to display in the legend from the createMap response.
var legendLayers = arcgisUtils.getLegendLayers(response);
legendDijit = new Legend({
map: map,
layerInfos: legendLayers
}, "legend");
legendDijit.startup();
the Map gallery
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title></title>
<link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
#map{
padding:0;
</style>
<script src="https://js.arcgis.com/3.16/"></script>
<script>
var map;
require([
"esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils",
"dojo/parser",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
"dojo/domReady!"
], function(
Map, BasemapGallery, arcgisUtils,
parser
parser.parse();
map = new Map("map", {
basemap: "topo",
center: [-105.255, 40.022],
zoom: 13
//add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
var basemapGallery = new BasemapGallery({
showArcGISBasemaps: true,
map: map
}, "basemapGallery");
basemapGallery.startup();
basemapGallery.on("error", function(msg) {
console.log("basemap gallery error: ", msg);
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline', gutters:false"
style="width:100%;height:100%;margin:0;">
<div id="map"
data-dojo-type="dijit/layout/ContentPane"
data-dojo-props="region:'center'"
style="padding:0;">
<div style="position:absolute; right:20px; top:10px; z-Index:999;">
<div data-dojo-type="dijit/TitlePane"
data-dojo-props="title:'Switch Basemap', closable:false, open:false">
<div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;">
<div id="basemapGallery"></div>
</div>
</div>
</div>
</div>
</div>
</body>
</html>
Also,as you can see in my code i have a legend, scalebar, and overview map that i need as well. Can anyone help with this i dont really care what the layout looks like just as long as my map shows up on top of the basmap gallery and i can change the basemap and yet have my data stay put.
