iis express worker process has stopped working on any geometric/topologic process on server. fault module name : ExtTopoEngine.dll
4430
12-16-2015 04:08 AM
CBSSube_Mudurlugu
Hi. I have been developing arcgis desktop applications for a long time. İ was using arcgis 9.3 for my applications. We upgraded to arcgis 10.3.1 now. But i have an error on my web service(.asmx). When i do any kind of geometric process i get the following iis error.
"iis express worker process has stopped working". error occurs on exTopoEngine.dll
Even this very simple code as below throws this error on topologicOperator.Simplify(); if i skip simplfy, it throws the same iis error on      IPolygon polygon = topologicalOperator.Buffer(1) as IPolygon;.
ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Desktop);
                AoInitialize init = new AoInitialize();
                if (init.IsProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeArcServer) == esriLicenseStatus.esriLicenseAvailable)
                    init.Initialize(esriLicenseProductCode.esriLicenseProductCodeArcServer);
                else
                    throw new Exception("ESRI ArcGIS Server License is unavailable or has failed");
                IPoint[] points = new IPoint[5];
                for (int i = 0; i < points.Length; i++)
                    points = new PointClass();
                points[0].PutCoords(0, 0);
                points[1].PutCoords(0, 10);
                points[2].PutCoords(10, 10);
                points[3].PutCoords(10, 0);
                points[4].PutCoords(0, 0);
                IPointCollection4 pointCollection = new PolygonClass();
                IGeometryBridge geometryBride = new GeometryEnvironmentClass();
                geometryBride.AddPoints(pointCollection, ref points);
                IArea area = pointCollection as IArea;
                ITopologicalOperator topologicalOperator = pointCollection as ITopologicalOperator;
                topologicalOperator.Simplify();
                area = polygon as IArea;
K2Sistemas
I have the same problem... Do you resolved? CBS Sube Mudurlugu
SamNeefs
We have the same / a similar problem, also after upgrading to 10.3.1.
Here IIS (express and regular IIS) also crashes because of ExtTopoEngine.dll
In the Windows log I could see that ExtTopoEngine.dll is the reason of the crashes.
Faulting module path: C:\PROGRAM FILES (X86)\ARCGIS\DESKTOP10.3\BIN\ExtTopoEngine.dll
We are also calling a method on topologyOperater, altough we are calling "ConstructUnion" when it crashes.
This is our complete code:
        public static object MakeUnionGeom(dynamic geoms)
            List<IGeometry> iGeoms = ((List<object>)geoms).Cast<IGeometry>().ToList();
            IGeometry geometryBag = new GeometryBagClass();
            IGeometryCollection geometryCollection = geometryBag as IGeometryCollection;
            for (int i = 0; i < iGeoms.Count; i++)
               IGeometry shp = iGeoms;
                object missing = Type.Missing;
                geometryCollection.AddGeometry(shp, missing, missing);
            ITopologicalOperator unionedPolygon = new PolygonClass();
            unionedPolygon.ConstructUnion(geometryBag as IEnumGeometry);
            return unionedPolygon as IPolygon;
SamNeefs
Did you find a solution?
K2 Sistemas
ibbcbs
