Im trying to plot a certain amount of points within a certain distance from eachother. Is there a tool that allows me to input a specifed number of points at a specified distance from eachother...more of an autocad question but want this is Arc.
1140
03-16-2017 06:14 PM
JeffCarlo
I have a polygon of a piece of land, I need to place 9 points within the polygon at 10 ft centers. How can I do this without placing a point and using the ruler or doing a 10 ft buffer on the point?
DanPatterson_Retired
check the Arcscripts Code sharing Site ple there are all kinds of tools to create point patterns.. for example.....
JeffCarlo
I will check it out...thanks!
JayantaPoddar
MVP Esteemed Contributor
You can also try creating Fishnet with an optional point dataset containing centroids of each cell.
Think Location
or hexagons.... But make sure that you are using a hexagon's centres if they have to be 10 units in the diagonal direction as well.  If the axis oriented centroids are sufficient, then this would just be an extra step
