Using ArcDesktop, not Runtime or Pro:
I'm written a little java program that reads through some shapefiles, grabs some data, runs certain calculations, and outputs an Excel Workbook with those calculations. I'd intended it to be an ArcCatalog add-in, but the apache jars for the Excel Workbook seem to be causing a problem.
Alright, so I'll wrap it up as an independent executable, then. Simple enough.
Well, the .exe doesn't run any of the program which interacts with the arcobjects.jar at all. Skips right over it.
So,
If I try as executable, the arcobjects jar is the problem.
If I try as add-in, the apache jars are the problem.
I've made sure that my IDE, my jvm, and my executable wrapper all can only run 32-bit, not 64-bit.
I'm stuck!
Is there a particular, necessary step to exporting my java code to an .exe that engages the arcobjects jar? Something I might have missed?
Is there any particular library that's compatible with ArcDesktop that allows one to write an excel file, as apache seems to be an issue with java add-ins?
Thanks.
