Need help creating a dynamic map
2034
02-11-2016 12:15 PM
JamesKruse
Here is the steps for creating a map
1 the user selects criteria for creating a map and a set of records are created containing userMapId, county fips code and a color code (1-6)
2 the records are put into a geodatabase (all user's map request data goes into this geodatabase
And now that the data is there we have a service that has a map with the database connected to it
( http://walk.ceris.purdue.edu/arcgis/rest/services/maps/county_map/MapServer  )
We need to be able to call the service with the user map id  ie:  ?mapid=5548793393
then render the map with the countys (using county fips codes) colored by using the color code.
The color codes are 1-6 which will have to be converted into a color (at this time the color could be any hex codes)
Attached is part of the database and what the current map looks like and what we want to do.
I hope this makes sense what we want to do
Any help is greatly appreciated as we are in real need for a solution
you may contact me @ jakruse@purdue.edu
Thanks so much
James Kruse
