I'm using Polygon to Raster tool to create a raster (10x10). The problem is that some cells of the output raster is not assigned any value.
My understanding is that the tool always uses the cell center to decide the value of a raster pixel.
Attached is the result when I overlay both the output raster and Input polygon on ArcMap. (Black is the NoData cell).
Anyway to include all those cells that fall within the polygon when generating the raster?
I tried to use Feature Vertices to Points to generate the point and convert the points to raster, but the vertex of the polygon that I used only have 1 vertex.
Another item to note is when using smaller cell size (1x1), the raster cell generated are good but when I resample it to 10x10, the output raster from resampling is the same as above raster.
