I want to do DEM Reconditioning. For this purpose I have used DEM and stream. I do several operations on DEM and stream.
I am using .NET in arcGIS 10.2
# From stream , I made streamRaster with ....conversionOp.ToRasterDataset((IGeoDataset)feaureClass, "GRID", workspace, string_RasterName);...
# Then I do .... >>>> logicalOp.IsNull((IGeoDataset)streamRaster); >>> mathOp.Minus(rawDEMGeo, smoothDropGeo);>>>conditionalOp.SetNull(conditionGeo, smoothDropFromDEMGeo);
and so on...
All this works fine If the input DEM is outside a gdb. But when The input DEM is inside a gdb, when I am going to do >>conditionalOp.SetNull(conditionGeo, smoothDropFromDEMGeo)<< this operation, an exception throws and it says an temp raster like (g_g123) can not open.
In arcGIS 10.0 , DEMReconditioning works well for both inside gdb DEM and outside gdb DEM.
arcgis 10.0 and 10.2 any differences ?? Or how I can I overcome this .....
IRasterDataset streamRasterDataset = rasterFromFc.CreateRasterFromFc(_agreeStreamFC,_rawDEMRaster, "D:\\W", 10000);
IRaster streamRaster = streamRasterDataset.CreateDefaultRaster();
IConversionOp conversionOp = new RasterConversionOpClass() {
OutWorkspace = rasterFromFc.WorkSpace
IRasterMakerOp rasterMakerOp = new RasterMakerOpClass() {
ILogicalOp logicalOp = (ILogicalOp)new RasterMathOps() {
IMathOp mathOp = (IMathOp)new RasterMathOps() {
IConditionalOp conditionalOp = new RasterConditionalOpClass() {
IDistanceOp distanceOp = new RasterDistanceOpClass() {
Console.WriteLine("Making buffer constant grid ..");
IGeoDataset bufferGeo = rasterMakerOp.MakeConstant(bufferDist, false);
Console.WriteLine("Making smooth constant grid ..");
IGeoDataset smoothDropGeo = rasterMakerOp.MakeConstant(smoothDrop, false);
Console.WriteLine("Making sharp constant grid ..");
IGeoDataset sharpDropGeo = rasterMakerOp.MakeConstant(sharpDrop, false);
IGeoDataset conditionGeo = logicalOp.IsNull((IGeoDataset)streamRaster);
IGeoDataset smoothDropFromDEMGeo = mathOp.Minus(rawDEMGeo, smoothDropGeo);
Console.WriteLine("Computing smooth drop/raise grid ..");
IGeoDataset smoothGeo = conditionalOp.SetNull(conditionGeo, smoothDropFromDEMGeo);// in ArcGis 10.2 , exception here
Console.WriteLine("Computing vector distance grid ..");
object obj = null;
object obj2 = null;
IGeoDataset vectorEucDistGeo = distanceOp.EucDistance(smoothGeo, ref obj, ref obj2);
smoothGeo = mathOp.Int(smoothGeo);
