Table widget with record editing capabilities
638
08-15-2016 11:29 AM
JonathanClark2
Hi:
I am looking for a custom table widget for Portal for ArcGIS where, if you have a service with feature access enabled, you can edit the feature attributes from the table.  I can't seem to find anything like this and the out-of-the-box table widget in WAB says that editing functionality is not currently available.  I would think this would be a commonly needed feature in a web app.  All of the other editor-type widgets seem to want the user to pick the feature from the map and then edit it in a special pop-up attribute window.  In my particular case, I don't want to enable the user to edit the features, only the attributes....
Any advice?
Thanks!
