Trigger find() or search method of Geocoder widget friom programmatic enter or return event on Sear_input
499
04-27-2017 08:35 AM
amitchavan
I am utilizing a Geocoder widget for my company project and it is being used in our website as an iframe. I want to trigger find() to invoke search_input
The Geocoder search input in teh below html gets populated when I enter an address in the parent html and the Requirement is when I click submit from parent window, or focus outfrom the field in parent window I want to fire search in the autopopulated Geocoder search input.
The Geocoder input doesn't search even if I programmatically click no the search icon using
1. $("div.esriGeocoderSearch.esriGeocoderIcon").click(); doesnt work
2. Nor a programamitc Keydown event on search input ofteh Geocoder  works
Is there a away to call the geocoders find() from another method to trigger the search like using something as  geocoder.find();
Here is the mapless.js which is being utilized in the html
require([
"esri/map",
"dojo/dom",
"dojo/on",
"esri/tasks/query",
"esri/tasks/QueryTask",
"esri/dijit/Geocoder",
"dijit/form/RadioButton",
"dojo/parser", "dijit/registry",
"dojo/domReady!"
], function (Map, dom, on, Query, QueryTask, Geocoder, RadioButton, parser, registry ) {
parser.parse();
var queryTask = new QueryTask("http://services2.arcgis.com/mJaJSax0KPHoCNB6/ArcGIS/rest/services/DACTracts30/FeatureServer/0");
geocoder = new Geocoder({
//map: map,
autoComplete: true,
arcgisGeocoder: {
placeholder: "Please Enter an Address",
sourceCountry: "USA",
postfix:"CA"
}, dojo.byId("search"));
//geocoder.on("select", showResults);
geocoder.on('find-results', showResults);
geocoder.startup();
function showResults (evt) {
console.log(evt);
if(evt.results.results.length > 0){
console.log(geocoder.results);
//var point = evt.result.feature.geometry, DAC;
var point = evt.results.results[0].feature.geometry;
var lat = point.getLatitude(), lon=lon=point.getLongitude();
var query = new Query();
query.returnGeometry = false;
query.outFields = ["CENSUS_TRA","COUNTY","CITY","CES_3_0_Sc"];
query.geometry = point;
console.log(point);
queryTask.execute(query, function (featureSet) {
console.log(featureSet);
console.log(featureSet.features.length)
if (featureSet.features.length==0){
DAC= 'Location is not within a Disadvantaged Community';
} else { DAC='Location is within a Disadvantaged Community'};
console.log(DAC);
resultItems = [];
var resultCount = featureSet.features.length;
for (var i = 0; i < resultCount; i++) {
var featureAttributes = featureSet.features.attributes;
for (var attr in featureAttributes) {
resultItems.push("<b>" + attr + ":</b> " + featureAttributes[attr] + "<br>");
resultItems.push("<br>");
dojo.byId("geocodeResults").innerHTML = DAC;//resultItems.join("");
} else {
dojo.byId("geocodeResults").innerHTML = "Address not found";
//geocoder.clear();
//geocoder.destroy();
And the HTML is as follows:
<html>
<head>
<title>Mapless DAC locator</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.19/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.19/esri/css/esri.css">
<style>
html, body {
font:normal 12px verdana;
.results {
background-color:#eee;
width:300px;
height:35px;
text-indent: 10px;
.dijitCheckBoxInput {
opacity: 100;
.dijitCheckBox, .dijitRadio, .dijitCheckBoxInput {
width: 14px;
</style>
<script src="https://code.jquery.com/jquery-3.2.1.min.js"></script>
<script src="https://js.arcgis.com/3.19/"></script>
<script src="http://localhost:3000/js/trigger.js"></script>
<script src="http://localhost:3000/js/mapless.js"> </script>
</head>
<body>
<b>Please enter the property address:</b><br>
<div id="search" style=""></div>
<br>
<span id="info"></span>
<br>
<div id="geocodeResults" class="results" style="text-indent:10px;"></div>
<div id="bldgResults" class="results"></div>
</body>
</html>
amitchavan
Its been amost a amonth and I don't find an answer to this question in any of the ESRI ARGIS forums or stack overflow.. So I just added this question here.
Does the find() method of Geocoder work??? when called from the method outside using
Does GEcoder Widget search input take programmatic enter events when triggered?
Can you please provide a smaple code or suggestion..to make this work
