What is the structure of a multipoint shapefile dbf file?
3933
12-19-2015 10:37 AM
AntonSawka
I'm writing a program to create a multipoint shapefile (.shp .shx .dbf), and I'm not sure how the format of the .dbf file should look. The .dbf starts off with a record header, followed by field subrecord structures, which are then followed by the actual records. The records start with a deletion flag followed by data.
With the consideration that this is a multipoint shapefile, how would the records be written? Is each point in the multipoint file a record or are all of the points considered to be one record?
DanPatterson_Retired
the shapefile specification is here https://www.esri.com/library/whitepapers/pdfs/shapefile.pdf
the shape field will contain the multipoint geometry to which one attribute in the dbase file is associated, hence, the multipoint designation, multiple points to one attribute
There are numerous threads on dbase format on the web dbase IV I think is the one being used, so you might query those as well... for example... http://www.dbase.com/KnowledgeBase/int/db7_file_fmt.htm
rather than reinvent the wheel, you might want to look at some packages that do it already ... ie for python pyshp 1.2.3 : Python Package Index
And there are builtins that can be used within arcpy to generate multipoints and export attributes out to shapefile format if you need. those
