Where are Topology Errors in Registered as Versioned data stored?
593
11-11-2016 02:11 AM
AsteriosTselepis1
I have a geodatabase on SQL server 14, and I want to access/view the results of a topology geoprocess  on Registered as Versioned dataset. Does anybody knows where this piece of information is stored when data is Registered as Versioned? The tables T_1_POLYERROS,T_1_POINTERROS,T_1_LINEERROS as I can understand contains the results of the Validation tool but when the data is NOT Registered as Versioned or when you reconcile/Compress the geodatabase, so I am guessing that there must be somewhere that the results are stored when data is Registered as Versioned, Where??
Another thing that I figured out is that when trying to access the results through python script (arcpy.ExportTopologyErrors_management) I get the correct data, but where are they stored in the Geodatabase?
Regards,
Stelios
George_Thompson
Esri Frequent Contributor
Hi Stelios,
You may want to review the information here: Topologies in a geodatabase in SQL Server—Help | ArcGIS for Desktop but remember that if the data is versioned it will be in the Delta tables for the topology.
Why do you need to get at those records in the delta tables?
--- George T.
