Working with secure ArcGIS services in gadgets
2531
03-31-2015 01:30 AM
SmithaNivesh
Hi, I am using secure map services using token based authentication in my application.
When I use the application from desktop token works fine but, when I open the same thing in ipad, it gives an alert to enter the credentials to access the services. But, token is getting generated properly in both.
Please help if someone has encountered the same and got a solution.
