I work with ArcGis 10 and Flex Viewer 2.3 and I want to add the Geoportal Search Widget for Flex for testing in my application.
I tried to compile with the source but I have This message in the Flash Builder 4.
[Bindable] on 'spatialReference' getter requires a locally defined setter. WMSLayer.as /FlexViewer/src/com/esri/gpt/wms line 1077 Flex Problem
1172: Definition com.esri.gpt.flexviewer.widgets could not be found. GptUserAlert.mxml /FlexViewer/src/widgets/GeoportalSearch line 38 Flex Problem
what's the problem ?
How do you do?
Do you have a link url to download the compile version swf ?
Thanks you very much
