Trek2There Updated - 3.0.36 Available
2643
7
06-28-2018 07:03 PM
JohnathanHasthorpe
Trek2There has been updated! Version 3.0 includes a number of fixes and some exciting new functionality.
The biggest change to Trek2There is that you can now connect to external GNSS receivers. The most common connection we expect users to try is a Bluetooth connection to a receiver from Trek2There on your Windows, iOS or Android device, but you can also connect via USB (on Windows) or a TCP/IP connection (any device) to a receiver on the same network.
External GNSS receiver support
To see what devices should work with Trek2There see: Supported devices.
To connect to a GNSS receiver in Trek2There you must first pair it to your device. Typically, launch the Bluetooth settings page on your device, browse for your receiver and connect to it. For more information on pairing see: API Guide.
Once your receiver and device are paired, you can browse for the receiver in Trek2There. To do this:
- Launch Trek2There
- Go to the settings page and choose ‘Use external receiver’
- On the search external receiver page, select the receiver from the list. Once you are successfully connected, you will be returned to the settings page.
- Enter a destination and return to the navigation page. On the navigation page, you will see the distance and bearing to your destination. Whilst you are using an external receiver, you will see an icon in the top right-hand corner (looks like a satellite). This indicates that the external receiver is in use. If this icon disappears, it means you have switched to using the internal position source (for example, perhaps the external receiver’s power has gone off).
If you shut down Trek2There and restart it, the external receiver should be remembered and you shouldn’t need to configure it again. It will take a few seconds to reconnect, but it should be automatic. Whilst it is connecting you should see a progress icon in the top right-hand corner of the navigation page (where the satellite icon will display).
Using Trek2There with an external receiver is a great way to navigate to a feature or location that is not in a published route-able network. It's also a good way for you (and us) to get ready for GNSS receiver integration in other Esri apps. Sneak peak: Based on this work in Trek2There, Survey123 will be getting the GNSS receiver makeover next!
Bug fixes and other improvements
- A destination can now be entered as decimal degrees, degrees minutes seconds, degrees decimal minutes, UTM (WGS84) or MGRS coordinates.
- Bearing values is displayed on the navigation page (as well as the direction arrow).
- Accuracy value now shown to two decimal places.
- Reduced direction arrow bouncing when stationary.
- Now when using the experimental compass mode, you will see a compass indicator in the top left-hand corner of the navigation page as a reminder.
- Improved timing and display of arrival at your destination.
- Improved speed in getting a 'fix' when Trek2There is launched from another app.
- Coordinates can now also be copy / pasted from another app on Android (previously only iOS).
- On Windows, when you launch Trek2There from another app, a new instance is no longer launched if an existing one is already open
Downloads:
iOS: Trek2There on the App Store
Android: Trek2There on Google Play
Windows: Trek2There™ – HockeyApp
Tags (1)
7 Comments
AlisonWalker
Hello Johnathan,
Trying to use Trek2There on iOS with an R1 receiver.  I have GNSS Status installed and set to output the required NMEA sentences.  But when I go into the app and try to set the receiver, I can't turn on Discoverable and therefore, I can't choose the R1.  Is there a workaround for this?
Alison
JohnathanHasthorpe
Hi Alison
Trimble devices are not supported on iOS devices (as Survey123 is not whitelisted for use). You should have success with Windows and Android though.
Thanks
John
AlisonWalker
Thanks Johnathan.  Appreciate the confirmation.  Just FYI, the Trimble R1 and R2 are listed as supported on iOS in that link above for supported devices.
JohnathanHasthorpe
Noted - we will get this fixed in the next doco release.
AlisonWalker
That's great, thanks Johnathan!
MichaelPittinger
Hi Johnathan-
Similar to the issue outlined above, I'm trying to use a Leica GG04 which is listed as compatible in the linked documentation.  However, I'm unable to enable "Discovery" of this external device in Trek2There when the GG04 is paired to an iOS device.  Any chance that this can be enabled?
Mike
DanielPanek
New Contributor II
Hello Johnathan Hasthorpe,
I'm trying to call Trek2There from a pop-up in Collector(Classic) - (developing for Windows devices, trying to provide a "navigate to" solution) .. I've seen the ability to use URL calls - e.g. arcgis-trek2there://?stop={Point_Y},{Point_X} .... but wondering if there is any way to configure the call URL to recognise UTM coordinates?
Appreciate any advice you can provide
Thanks
Dan
#trek2there
