You're working at or with an electric utility.
You too see ArcGIS Utility Network [UN] as the right foundation for your data driven operation.
UN is not a plug and play solution, though. The number of LinkedIn posts highlighting how you need to conduct extensive analyses on your source data and on how to implement UN to support your needs are endless.
To meet the challenges lying ahead for DSOs we must collaborate. We should unify implementations. And why not do so - after all: DSO is DSO; Why would everyone have to go through the same clarification?
Join us at hashtag#IMGIS2024 in Frankfurt where Volue will present a white paper allowing you to jump-start your UN journey if your a DSO operating a balanced three-phase electric grid. A white paper created in close collaboration with Norway's largest DSO serving one million meters, Elvia.
https://www.linkedin.com/feed/update/urn:li:activity:7181214042487758850/
