I am trying to make changes to a built-in widget. As an example, let's say I want to take Map Layers widget and modify it:
I want to change transparency to a slider, instead of current buttons. What I did was to find widget files from ArcGISExperienceBuilder\client\dist\widgets\arcgis\map-layers and create a new custom widget from them. I started working with them and noticed that it uses DataActionList like this:
<DataActionList widgetId={this.props.id} dataSet={dataSet}></DataActionList>
If I want to add a new action to the list of actions in this widget, how do I generate html component for it? I checked DataActionList and it only takes a buttonType:
/// <reference types="react" />
/** @jsx jsx */
import { React, type IMThemeVariables, type DataRecordSet, type ThemeButtonType } from 'jimu-core';
import { type ButtonSize } from './button';
export declare enum DataActionListStyle {
IconList = "ICON_LIST",
List = "LIST",
Dropdown = "DROPDOWN"
interface Props {
/** The widget id that is using this data-action list */
widgetId: string;
/** Whether it's batch-action, which passes in dataSets */
isBatch?: boolean;
/** The dataSet used for generating data-action list */
dataSet?: DataRecordSet;
/** The dataSets used for generating data-action list, it should work with isBatch field */
dataSets?: DataRecordSet[];
/** The data-action-list style, could be 'list', 'icon-list' or 'dropdown' */
listStyle?: DataActionListStyle;
/** The dropdown-button type */
buttonType?: ThemeButtonType;
/** The dropdown-button size */
buttonSize?: ButtonSize;
/** This component displays available DataAction in an list, icon-list or dropdown style.
* Widgets that need to use DataAction can use this component.
* To display in a specific style, just pass `listStyle` with 'list', 'icon-list' or 'dropdown'
* You can use this component by:
* `import { DataActionList } from 'jimu-ui'`
export declare const DataActionList: React.ForwardRefExoticComponent<Pick<Props, keyof Props> & {
theme?: IMThemeVariables;
export {};
how do I modify things to add a slider for the map-layers, without writing the whole thing from scratch and incorporating it to the current Map Layers widget.
