Annotation Class (SDE)
2138
14
02-06-2018 02:24 PM
DanKerntop
We have a standard annotation class in a few datasets in SDE that do not allow us to add, delete or rename the annotation classes in the properties.  However, we are able to do this in a file geodatabase.  We are using ArcMap 10.5.1.  Has anyone else had this issue and if so, how did you resolve it?  Finally, we have contacted ESRI and they are unable to provide an answer.
DanKerntop
Hello Shan,
1. What is the License level for ArcGIS Desktop? 10.5.1
2. Did you create a map annotation or an annotation feature class? Annotation feature class in SDE
3. The feature class residing in the enterprise database, is it already participating in any complex relationship (e.g. Network dataset, Geometric dataset. Yes, it is part of a Network dataset with simple and complex edges, etc. I may try moving the annotation feature to a separate feature dataset without the network….
Regards,
Dan Kerntop
GIS Analyst
City of Wausau
Dept of Public Works
407 Grant St
Wausau, WI 54403
City of Wausau
Office: (715) 261-6757
Learn more about
the City of Wausau at:
www.ci.wausau.wi.us<http://www.ci.wausau.wi.us/>
shan_sarkar
License level would mean (Basic, Standard, Advanced) 10.5.1 is the version of the product.
The annotation that you are trying create are they feature linked annotations?
~Shan
~Shan
DanKerntop
1. 10.5.1
2. Feature class anno
3. It doesn’t seem to matter if it’s in a network
Also, when I turn off ArcGis Server, then I can make changes to the feature class anno properties..
Dan
ThomasColson
MVP Frequent Contributor
My knee jerk answer as that you have an orphan schema lock. In db admin, go to connections, and kill them all (like Pokemon). My second knee jerk answer is...can you post a screen shot(s) of exactly what/how you're trying the operation? You may be in a known limitation....
DanKerntop
The desktop and license manager are running 10.5.1
It doesn’t seem to matter if the anno feature class is in a geometric network or not. When I stop running ArcGIS Server it allows me to change the anno classes in the anno feature class. I just don’t want to have to stop ArcGIS Server to make changes. Schema locks are bad enough withit.
Thanks for your Reply,
Dan
