Find ST_GRIDS using query Oracle 19c
498
11-28-2022 08:50 PM
yockee
Occasional Contributor II
I need to rebuild my spatial indexes using query. This is the query that I am expecting to run :
CREATE INDEX SDE.A280_IX1
ON BANGKAIKAPAL_PT_1K(SHAPE)
INDEXTYPE IS sde.st_spatial_index
PARAMETERS('st_grids=1,3,0 st_srid=32748 tablespace NEW_TBS');
I need to find st_grids value using query. How can I do that ? I have been searching the web and can not find anything.
What I want is something similar in finding SRID : "SELECT sde.st_srid (SHAPE) sridcol FROM SDE.STREET;"
Thankyou
FrédéricPRALLY
Hi Yockee,
From ArcCatalog you can use this tool Calculate Default Spatial Grid Index or refer to this article Guidelines for choosing a spatial index grid size
Hope this help you,
Best regards
sorpigal
A bit late, but this is how you can find a existing st_grids value from an existing spatial index:
select sgi.grid.grid1 || ‘,’ || sgi. grid.grid2 || ‘,’ || sgi. grid.grid3 as grid from sde.st_geometry_index sgi where owner = ‘SDE’ and table_name = ‘STREET’;
