Geodatabase Roles
5687
08-22-2014 09:29 AM
StevenGraf1
Occasional Contributor III
Are the ESRIAdmin, ESRIReadData, and ESRIWriteData roles suppose to be in there by default?  They aren't there in our databases.  I had to create them before I could apply permissions.
RussellBrennan
These roles should be created when using SQL Express workgroup or desktop geodatabases. However if you are using enterprise geodatabases these roles are not created.
Types of geodatabases:
Geodatabase | Multiuser Geodatabase
RussellBrennan
StevenGraf1
Thanks for the speedy reply!
Is there a reason these aren't created for enterprise?
RussellBrennan
Geodatabases on the SQL Express platform were traditionally managed solely through ArcCatalog. This was done to provide an easy user experience to the geodatabase admin. Through ArcCatalog there were options for adding users, backing up and restoring the database. There were also options for viewing and managing user privileges. We provided what we felt was a few (suitable and easy to understand for SQL Express admins/users) roles that admins could use to administer privileges. These are the roles that you were asking about. We did not however, provide an option for creating new roles.
With enterprise geodatabases on SQL Server we do not limit what roles you want to use and do not make any assumptions about the roles you want to create. This gives more flexibility to admins who want more discreet or more general roles for their organization. These admins typically configure and manage their geodatabases using a combination of SQL Server Management Studio as well as ArcCatalog.
