Hello Biraja,
I hope I have answer your questions below.
1. Is this a new replica
Yes, this is a new replica. There will be always two way replica between Sde1 and Sde2 schema.
2. Is synchronization failed, if yes what is the error message
Actually no. We are trying to design a new architectural system between databases by using Esri replicas. In which posibble scenarios, synchronization might be failed. If we get into this replica system, what possible errors we might take. Which we want to make sure before starting a new our design.
3. What makes you think replication is corrupted
I didn't encounter for replication to be corrupted before. But I just want to check every possible scenarious before implement this architecture to customer's system.
4. Can you please provide your workflow to create replica and editing and synchronization
Actually in simpler version of workflow, that's how I can explain:
Our main database will be Sde1. Mobile users will download their data by using Sde2. And they will do so their replica databases which will get this done in Arcgis Server.
After mobile users completed their work, they will post their data to Sde2 schema which is without geometric network.
After submitting their work, power user will start sync between sde1 and sde2 schemas.
After this workflow, I don't want to get any geometric network error in sde1.
5. Why you need 2-way replica
After sending data from mobile tablets which they don't use geometric network on mobile db, I have had got some errors in geometric network because of connectivity problem. I want to get it done by using 2-way replica.
Murat Demircan
