how to get all the coded value from a domain in an SDE to a table
2733
04-26-2016 10:38 AM
lelaharrington
New Contributor III
trying to get all the values of a domain so i can check it for updates that are needed. i would like to get it in tabular form and then bacble to modify and republish it to the domain when completed.
WesMiller
Regular Contributor III
ThomasColson
MVP Frequent Contributor
This will create a view (sort of table) that will display your coded value domain:
CREATE VIEW [dbo].[View_Landform]
AS
SELECT    codedValue.value('Code[1]', 'nvarchar(max)') AS
, codedValue.value('Name[1]', 'nvarchar(max)') AS [Value]
FROM        dbo.GDB_ITEMS AS items INNER JOIN
                      dbo.GDB_ITEMTYPES AS itemtypes ON items.Type = itemtypes.UUID CROSS APPLY items.Definition.nodes('/GPCodedValueDomain2/CodedValues/CodedValue')
                      AS CodedValues(codedValue)
WHERE    itemtypes.Name = 'Coded Value Domain' AND items.Name = 'Landform'
GO
The edit method described in Re-order Attribute Domain Values  can also be used to execute the edits you desire without having to remove the domain from the FC attribute and re-import it.
JenniferMcCall4
Occasional Contributor III
You can also check out XRay http://www.arcgis.com/home/item.html?id=e1e911d7d7374285b1ef03d06b3ee642 .
I believe you can use this to push domain edits back into the GDB.
