I think i went to long between reconciling and posting
2559
10
09-19-2016 08:13 AM
RandallClark2
Occasional Contributor II
So i think i made a mistake and went to long with reconciling my QA version with its parent DEFAULT version.
I say this because I started the reconcile process on a friday afternoon and its now Monday and it is still going on, luckily no errors.
This reconcile is taking place outside of an edit session and is being handled in ArcCatalog via Administer Geodatabase
So my question is what do i do?
Do  i just let it keep running till it finishes and learn my lesson.
Or is there something else i can do?
RobWilkes
In the end I had to call ESRI Tech support. They helped me out and narrowed the error to our topology and roads. I had to remove the feature data-set and run the check and fix geometry tools. After everything was fixed just had to put it back in and version the feature data-set and we were right as rain.
