As the title says, for some reason I do not see posted edits at the database tier until the week after they're posted. I can't figure out why, I've looked through the relevant documentation and nothing about this. We are using ArcGIS 10.2.1. Our SDE is using oracle 11g.
For example: if I start an edit session and new version, edit a point feature and then post it on say Wednesday, it will be visible in the default version within ArcMap after the posting completes. However, if I go to sql developer and query that same feature you will not see the edit until the next monday for some reason.
Am I not querying the default version using sql developer? What's going on here?
Thanks!
